Hola a todos,
Queria compartir esta belleza que me encontre estan vendiendo. Parece recien salida de la ensambladora.
El problema: piden 30.000 DOLARES por ella
http://s237.photobucket.com/albums/ff25 ... 109-green/Por la placa, parece que esta en Guatemala, pero la estan vendiendo en North Carolina, USA:
Aqui les pego el posting original con la descripcion:
"Frame off Rebuilt Series 1969 Series 109 IIa
Frame off Rebuilt Series 1969 Series 109 IIa This truck was taken down to the frame and built back up. Frame is in perfect condition. There is no rust on this truck. She has been well cared for with loads of money and time spent keeping her in original like new condition. This is a complete nut and bolt rebuild. You will not find another pair of series trucks like this for a long time. • The engine has been completely overhauled - pistons, valves, bearings, timing gears etc... A complete rebuild, the generator is also new old stock and not rebuilt. The radiator was replaced with a series 3 one for improved cooling • Vehicle mileage at 71k km is original to the truck. • Rear end was upgraded to a Salisbury rear end, and a slightly stiffer spring delivering a slight lift was added as well. • Truck was completely stripped and repainted inside and out. • Has the extremely hard to find safari roof. • Galvanized cappings • New galvanized front bumper • New headliner • New door cards • New seat coverings • All new bushings, brakes, bearings, shocks etc, • All new lighting and replaced most wiring to new. • Frame is excellent, floors are excellent, doors are excellent, bulkhead is excellent, Truck is rust free."
Saludos desde el Canada!
Yuri
