COLOR ORIGINAL
COLOR ORIGINAL
Notapor BOOKER » Jue Mar 26, 2009 10:11 am
HOLA A TODOS, QUISIERA HACER UNA PREGUNTA, EN Q COLORES ORIGINALES VENIA EL LAND ROVER SANTANA 1965, GRACIAS POR SU AYUDA, UN ABRAZO.
BOOKER
BOOKER
Re: COLOR ORIGINAL
Notapor OMAR » Jue Mar 26, 2009 2:51 pm
HOLA BOOKER Y BIENVENIDO A LA LEGIÒN LAND ROVER. :hello: :thumbsup:
HERMANO, ESTOS SON LOS COLORES ORIGINALES PARA UN SERIES INGLÈS DE 1.960:
.. NO HABÌA MUCHAS OPCIONES DE COLORES PARA LOS LANDYS EN ESA EPOCA.
ESTA ES LA TABLA DE COLORES CLÀSICOS EN QUE SALIERON LOS LAND ROVERS SERIES:
ADEMÀS LOS CÒDIGOS DE PINTURAS:
Paint Colors
Description Rover No. DuPont Ditzler Glasurit RM-Supermax Unipart
Pastel Green RTC4041A 38504* ROV-605 RV-028
Bronze Green RTC4042A 38500* 46451 LEY-637 RV-027
Marine Blue RTC4043A 38503* 16514 ROV-504 RV-017 GAP407
Limestone RTC4044A 38505* 46251 RV-040
Poppy Red 38506* ROV-303 RV-029
Sand 38502*
Mid grey 38501*
Burnt grey 38508*
Davos white 38514*
Mexican brown 38519*
Cameron green 38520*
Almond yellow 38521*
Sandglow "Camel Yellow" is also an old Jaguar color
Sand (ACF/004 or 26291)
Artic White
"Detroit Diesel Alpine Green" #225, made by Tempo.
*For DuPont add suffix "A" for Centari Acrylic Enamel, "L" for Laquer,
or "D" for "DuLux" Alkyd Enamel.
Primers, Cleaners, Converters, Thinners, etc.
Some colors require white primer, others grey.
Alpine White RTC6870A
White Primer RTC4055A
Grey Primer RTC4056A
DuPont
"Colar" Two-Part Epoxy Primer, available only in grey in gallon sizes.
"Dulux" Hardener 77-S
"Variprime" Two-Part Primer 615-S
"Variprime" Converter
Aluminum Cleaner 225-S
Aluminum Converter 226-S
Galvanized Metal Cleaner
Galvanized Conditioner
A.P. 'Sandy' Grice writes,
"Automotive paints are quite sensitive to temperatures: use the following thinners/retarders. If you must paint at higher temps, add an anti-wrinkle agent:
DuLux Thinner Temp Range Centari Thinner Temp Range
#8508 below 65 F #8034 below 70 F
#3812 65-75 F #8022 70-85 F
#3864 70-80 F #8093 above 85 F
#8522 above 80 F
"The DuLux cannot be clear-coated, though the Centari can be protected in this fashion. DuLux can be mixed for brush application (like for roofs) rather than spray application, though. DuPont "Corlar" two-part epoxy is another primer alternative. As it is intended for aircraft, it is only available in gallon cans, and in grey. Better living through chemistry... I wasn't trying to sell AB's paint, but only thought the color names might be of interest. Right you are on being able to buy it anywhere, and here are the match numbers, courtesy Rovers North. Don't blame me if you go out and get 10 gallons and it don't match. I got some Dupont acrylic enamel to paint my fire wall with this number and it doesn't match anything, but that's just because the thing is so fadded and oxidized. I'm sure these are as correct as you can get. And a lovley red it is."
SUERTE. LA IDEA ES DEJARLO DE UN COLOR ORIGINAL, NO ?..... SUBE ALGUNAS FOTOS PARA CONOCERLO.
Re: COLOR ORIGINAL
Notapor BOOKER » Jue Mar 26, 2009 6:27 pm
MUCHAS GRACIAS POR LA INFORMACION ESTA MUY BUENA, ESTOY NEGOCIANDO UN LAND SANTANA 65 AZUL, SI ME ACEPTAN LA OFERTA SUBO LAS FOTOS PERO ME ESTOY ANTICIPANDO UN POCO, LA VGERDAD ME TIENE EMOSIONADO EL TEMA DE TENER UNO Y DEJARLO LO MA SORIGINAL POSIBLE. UN ABRAZO.
BOOKER
BOOKER
Re: COLOR ORIGINAL
Notapor OMAR » Jue Mar 26, 2009 6:38 pm
PUES HOMBRE... POR ACÀ EN LO QUE PODAMOS COLABORARTE, CON TODO EL GUSTO DEL MUNDO :hello: .....
INCLUSO VARIOS AMIGOS LEGIONARIOS SE HAN HECHO ULTIMAMENTE CON UN LAND ROVER (PARECIERA QUE HAY ÈPOCAS... EPOCAS DE VENDER... EPOCAS DE COMPRAR LAND ROVER...., JE, JE ).
SALUDOS Y OJALA SE DE LA COMPRA, :thumbsup: .
Re: COLOR ORIGINAL
Notapor BOOKER » Jue Mar 26, 2009 6:43 pm
MUCHAS GRACIAS POR TU AYUDA UN ABRAZO.
BOOKER
BOOKER
Re: COLOR ORIGINAL
Notapor k1000o » Vie Mar 27, 2009 7:40 am
Hey Booker, bienvenido a la Legión Land Rover. Ojalá te hagas a una buena máquina, estoy seguro ...
Series III 1978
Series IIA 1969, Diógenes (guardado)
Re: COLOR ORIGINAL
Notapor Luis Carlos P » Vie Mar 27, 2009 7:56 am
Cordial saludo Booker, las tablas que te han plasmado son las pertinentes a la originalidad de estos LR, sin embargo, para que tengas mejor acierto, existen en Bogotá las placas o láminas con los colores originales de los LR, para poder ver al vivo el color aplicado.
Cualquier inquietud, y/o solictud, respecto a la recuperación de tú LR, con el mayor gusto.
Luis Carlos P
Re: COLOR ORIGINAL
Notapor RicBelP » Vie Mar 27, 2009 8:53 am
.... Hombre, Bienvenido a la Legión..... :thumbsup:
Re: COLOR ORIGINAL
Notapor BOOKER » Vie Mar 27, 2009 2:42 pm
LAS PLACAS DE LOS COLORES DONDE SE PUEDEN VER, GRACIAS
BOOKER
BOOKER
Re: COLOR ORIGINAL
Notapor Alejandro81 » Vie Mar 27, 2009 4:33 pm
Hola Booker, yo también soy nuevo acá.... wellcome y pon fotos del carro para que babiemos el teclado un rato!
Usuarios navegando por este Foro: edwin_cajica y 0 invitados
